Salta al contenuto principale
Informazioni sulla riparazione e sullo smontaggio dell'eReader Kobo Clara BW (bianco e nero) di Rakuten, rilasciato nell'aprile 2024. Identificato dal numero di modello N365.
Vertical scratch on the screen: is front cover sufficient?
Hi, I have a vertical scratch on my kobo clara bw, as seen in picture. Screen is fully functioning, but I am considering fixing.
Immagine
To repair, do I need to purchase an entire screen, or would replacing the front cover sufficient?
Thanks
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks. To clarify, the scratch I am referring to is the one on the "white" area (left of the book title), not the black cover on the bottom
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
It doesn't appear you got the answer you were looking for; as far as I can tell the front cover does not come with any glass or acrylic screen; it's nothing more than the shell around the screen.
As such, the only fix for the scratch you're seeing is to replace the entire screen. That basically means gutting the reader, putting in a new screen then rebuilding it with the parts you took off the original. The front glass on the screen is not considered replaceable; the separate layers are all bonded together, so you have to replace the whole thing at once. Here's the iFixit guide to that repair.
Kobo Clara BW (N365) Screen Replacement - iFixit Repair Guide
One note here; rather than answering, I almost skipped by your question because you had already marked the previous answer as accepted. When you do that, many of us volunteers will ignore it, assuming you've gotten whatever answer you were looking for, so you need to hold off accepting an answer until your question has actually been answered to your satisfaction.
Punteggio 1
Risposta più utile
Hey,
Just from looking at this photo, it appears the scratch is just in the front cover, it doesnt look to be screen damage.
Here is a guide to replacing to cover, also on the guide it will have links to everything you need to replace the cover.
Sostituzione cover anteriore Kobo Clara BW (N365)
Hope this helps, good luck!
Punteggio 1
Aggiungi la tua risposta
Francesco Gelli sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 61
Tutti i Tempi: 869
