Right joycon random inputs on his own
My right joycon at random times start pressing random inputs. Sometimes it is ok for 2 hours but then starts again
Questa è una buona domanda?
Hi!
Okay, so every button is pressing them selves? If this is the case, you might want to open the controller and check what’s going on!
First I would clean everything with isopropyl alchol and see if that works.
Otherwise, it is a motherboard issue here. Replacing this one can solve this kind of issue. But please clean it first and see how it goes!
I cleaned everything but now only the joystick works
Hmm, how are the SL and SR buttons? Also the ZR button, does this one work?
So, the A/B/Y/X buttons aren't working, but is the + and home button working?
Which buttons are failing at the moment? You can test any button on the Switch. Please follow this guide: https://en-americas-support.nintendo.com...
Please let us know which ones are working. Thanks!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 52
