Salta al contenuto principale
Laptop ultrasottile Processore: Intel Celeron N4120 a 1,1 GHz 1101 MHz Turbo Boost: a 2,6 GHz GPU: Intel UHD Graphics 600 8 GB RAM DDR4 256 GB SSD TPM 2.0 (supporta Windows 11) Dispone di lettore impronte digitali. Nessuna unità disco ottico. Fotocamera HD 720p. Kensington Lock 2x USB Type-A 3.2 Gen 1 (5 Gbps) 1x USB Type-C Bluetooth 5.1 Jack combinato da 3,5 mm Pannello dello schermo Full HD IPS Display 1080p a 60 Hz Viene fornito con EFI Shell preinstallato. (Windows è facile da installare)
Screen doesn't turn on
My screen started flickering and just went black I've tried everything still hasn't turned back on
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Does the computer appear to be on other than the black screen? If so, there are two things to try next.
  1. Shine a flashlight on the screen in a dark room. If the backlight has gone out, you'll still be able to make out an image on the screen; try different angles for viewing and the light.
  2. Try plugging in an external monitor; if you have a USB-C to HDMI adapter you can plug it into a television. Anyway, if the external monitor works then your LCD may have failed and would need to be replaced. Note that there may be key sequences you have to press to enable the external monitor; that should be documented in your users manual.
Give those things a try then come on back and let us know what you find.
Punteggio 2
Aggiungi la tua risposta
Light sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 244
