Salta al contenuto principale
Stampante HP Officejet a funzione singola introdotta nel 2015.
Printer won't pick up paper
That's basically it. It makes all the whirring noises but it does not collect paper from tray (and thus, says there's no paper). I've tried a single sheet, I've tried loading the tray full, but nothing seems to work. And I can't really see if the little roller-thingies move or not.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Wwas there a paper jam that you had to remove before this? Check from the from of the printer for torn paper in the paper path? Sometimes especially with modern printers that are basically made to be disposable ( unless you buy an business class printer) it’s had to see the cause without taking them apart! Check the paper path is clear! Try feeding some stiff card through it…
Punteggio 0
Aggiungi la tua risposta
Ma T sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 24
Tutti i Tempi: 191
