Salta al contenuto principale
Xiaomi Redmi Note 13 4G Released 2024, January 15 188.5g, 8mm thickness Android 13, up to 15 128GB/256GB/512GB storage, microSDXC
My wifi is not working properly
sometimes it disconnecting to the wifi or it indicates that no wifi connection but my wifi is working properly
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @leimalimban
Try using the phone's WiFi as close as possible to your home network router i.e. <15cm and check if the WiFi detects, connects and maintains the WiFi connection OK.
If it works OK, then it may be a faulty antenna/antenna connection that is the cause of the problem.
Here's an image taken from this teardown video of the phone, showing where the antenna is connected.
(click on image)
Punteggio 0
Aggiungi la tua risposta
lei malimban sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 380
