Salta al contenuto principale
The Dell Latitude 5400 is a 14 inch business class laptop designed for enterprise and educational use, offering a range of Intel 8th generation processors, and upgradeable components.
Sim card not showing or not working
After insert sim.card not showing tower range or not showing any other notification,sim.card not working
Questa è una buona domanda?
Punteggio 2
1 Commento
sim card not working
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @pravinpharande
Check in Device Manager > Network Adapters to see if the Intel XMM7360 adapter is working OK.
If it is there but not working (yellow exclamation mark or red cross) check that the latest version drivers for the adapter are installed (scroll down the list to find the XMM7360 drivers).
If it isn't shown in Network Adapter, check if it appears in Device Manager > Communication ports or Device manager > Unknown Devices.
Punteggio 1
Well I will suggest you to check the following:
1.Ensure the WWAN Card is Properly Installed
2.Check If Your Model Has a WWAN Module
3.Check BIOS Settings for that Reboot and enter BIOS and then Go to System Configuration > Wireless or WWAN>Make sure WWAN is enabled> Save and exit BIOS.
Punteggio 0
Aggiungi la tua risposta
Pravin Pharande sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 92
Tutti i Tempi: 474
