Salta al contenuto principale
Repair and disassembly information for Google's Pixel 7 Pro smartphone, released in October 2022. Identified by model number GP4BC and GE2AE.
Front screen replacement problems
Hey guys, have tried to replace the front screen twice now and everything is perfect until it comes to final placement of the screen.
Everything clicks and stick good except for the the lower right hand side of the screen.
This resulted in the first screen being damaged and the second one in the same problem.
There are no tabs out of place and everything is clean.
Could this be cause by a slightly swollen battery maybe?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Is your battery swollen? Have you tried a different parts supplier? Lastly, are you using the screen only repair or the one with the screen and frame?
Punteggio 0
Yikes, that’s a bummer! If the battery's swollen, it can mess with the screen fit. Better to address that first to avoid damaging another one!
Punteggio 0
Aggiungi la tua risposta
Tyson McDonald sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 90
