Salta al contenuto principale
Advanced GPS for Trucks, released in 2015, equipped with voice control and can easily be used on any truck.
Power button stays pressed in
My Dezl power button stays pressed in, collapsed, like the spring back function has failed. I power the unit on and off using by using the power cord. How can I fix the button myself?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @michael64904
Here's the ifixit Garmin Dezl 770LMT guide that may help.
Once the device has been opened you may be able to see what's wrong with the power button.
If the button itself is the problem, then there's not too many results when searching online for the button replacement part. This is about the only supplier that I could find. You may have better luck.
Punteggio 1
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 19
