Salta al contenuto principale
Discover the Craftsman Gas Snow Thrower 247.88787, a machine designed to clear snow from driveways and walkways using a rotating blade system. This page offers repair and detailed information about this gas-powered device, including its fuel capacity of 2.3 quarts and usage of 5W-30 engine oil.
Governor does not seem to be adjusting engine RPM
How do you test or know if the governor is working. I recently replaced the carburetor due to hunting and surging. The issue is resolved however now the snow thrower runs at WOT unless I choke it almost all the way.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @nelso78280
What is the make and model number of the engine, used in the snowblower?
Here's a video that shows how to set the governor in a Tecumseh engine that may gives you some ideas of what to check.
Punteggio 1
Aggiungi la tua risposta
nelso sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 27
Tutti i Tempi: 111
