Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
back light keeps going out
iPhone 4s sprint
my iphone works perfect 50 % of the time then the light goes out and if i push the bottons enough it will come back on but while the light is out i can still hear all my notifacations go threw. It dose this 2 or 3 times a day...... please help
Questa è una buona domanda?
Punteggio 0
2 Commenti
Did something happen to the phone before these symptoms started such as dropping the phone?
da
Yes I drop it once and then I plugged it in and it turned back on but now I drop it and now it won't come back on
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Send it back under warranty agreement
Punteggio 3
if the lcd and the connector connection have no problem then...
light blinks when the coil start to fail.
yeah your coil is probably bad, you need to change it.
youtube video on how to change the backlight coil to fix the backlight
http://www.youtube.com/watch?v=Bsk6rg0KX...
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,273
