Salta al contenuto principale
Guides and repair information for washing machines produced by Maytag, a subsidiary of Whirlpool.
Rubbing/screeching noise while agitating
Whenever my washer has a load in it it makes a intermittent rubbing sound, much like the sound of tires screeching on pavement, while agitating. I've run it empty and it doesn't do it. Trying to figure out what I need to look at and/or replace. I'm pretty handy so replacing something isn't an issue, just not so great at diagnostics.
Update (01/26/25)
Mod: MVW7232HW0
Ser: CX4900197
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @jorgefernando
Check if the wash plate is OK. It may be worn and slipping on the drive shaft.
Here's a link that has a video (scroll down the page a bit), that shows how to remove it to check.
If the plate is worn search online for W10902814 to find suppliers that suit you best. (examples only)
Punteggio 1
Does it make any noise when spinning with a load?
It sounds like the tub is hitting another piece of metal. That might be a problem with the suspension rods.
Punteggio 0
1 Commento:
Nope. When it's soinning it sounds fine. It's only when it's agitating.
da
Aggiungi la tua risposta
George Privat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 212
