Salta al contenuto principale
I think problem in motherboard how to resolve it
I have replaced my note 8 batteries at least 3 to 4 Times ,but it breaks my back panel and got fatty. It automatically switch off while using and when I turn on this handset ,it shows 0% battery and switch off again. It can be a motherboard problem- if yes then how to resolve it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If your phone suddenly switches off while using and then shows 0% battery when you turn it back on, immediately switching off again, the most likely culprit is a faulty or worn-out battery, which is no longer able to hold a charge properly and is likely nearing the end of its lifespan.
A few reasons why this might be happening:
  • Degraded Battery
  • Battery Damage
  • Loose Connections
Punteggio 1
Aggiungi la tua risposta
Parvinder General Store sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 91
