Salta al contenuto principale
The Lenovo G510 is a laptop designed by Lenovo and released in 2014 as part of Lenovo's G series of Ideapad laptops.
4 Domande Visualizza tutte
speakers have poor contact
when i shake the laptop the audio loudness changes (i have 100 volume on vindows)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @juragd
Does the volume change if you shake the laptop when listening to audio using headphones connected to the laptop?
If not try testing the Left and Right speakers in Control Panel > Realtek Audio Manager to see if only 1 speaker is the problem. If it is only one speaker then unfortunately they come as a complete module so you will have to replace both.
Here's the hardware maintenance manual for the laptop.
Go to p.69 (73 of 108 pdf) to view the procedure to remove the speakers from the laptop. Initially you don't have to remove them, just check their connection to the motherboard is OK and that they look OK as well.
If it is determined that the speakers themselves are faulty search online for 90202714 to find suppliers that suit you best.
Punteggio 1
Aggiungi la tua risposta
jura GD sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 15
