Il TicWatch E3 è uno smartwatch di Mobvoi alimentato da un SoC Qualcomm Snapdragon Wear 4100 e da una cella da 380 mAh. È stato rilasciato a metà 2021. Modello: WH12068
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento:
The question may be what's expected battery life before it wears out? A worn out battery may be the reason for your watch not powering up. One way to tell if the watch is faulty or a dead battery would be opening it and noting battery voltage, usually printed on the battery. A substitute battery of any size with correct voltage can be temporarily wired in after removal of the main battery. With correct connections, turn on your watch. If it turns on and runs, replace the battery. If this temporary battery doesn't turn on the watch, it's faulty and non repairable.
da F Dryer
