Salta al contenuto principale
the Dell Dimension 8300 was a high-end desktop hailing from 2003. it has socket 478 processor support and came with 4 GB of ddr2 RAM
7 Domande Visualizza tutte
Dell Dimension has no power
I'm having the same problem. My system will not turn on. Replaced the power supply. Still will not power up. Could this be a bad power button? Any help is appreciated. Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @tombell58613
Here's the service manual for the PC.
Select the Advanced Troubleshooting link on the Contents page and then check which diagnostic lights and their colour are turned on, on the back panel.
If there are any on, then depending on the colour combination, it represents a code showing what the problem may be.
Punteggio 1
1 Commento:
Thank you for the manual. I will try the advanced trouble shooting & let you know what I find out. Thanks again!
da
Aggiungi la tua risposta
tombell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 22
