Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti:
I assume the controller wont charge anymore either? Sounds like the battery has moved on. Swap in a different known working battery. If that works AND it charges just fine...then there's the culprit. However if a different battery works but does NOT accept a charge....the issue is somewhere in the charge circuit on the controllers main board.
da RebTech
It does work but on the charger only
da Brandon Spooky
