What soldering points can I use
I covered ther original soldering points with a drift mod and not I can't get to them is there another positive and negative point that I can solder to on the controller board?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Some pictures would go a long way here. You can add some to your original question. Use the tools in the photo editor to mark it up if need be.
da
Those "drift mods" are not ideal. They tend to bork the outer circularity accuracy. Personally by default I replace the stock graphene based modules with Hall Effect modules. I've never had a single controller come back for drift issues. Also a little time back someone created a calibration software for ps5 controllers. I recommend removing those "mods", ditch the graphene modules, install Hall Effect modules, calibrate, and be done with drift. Gulikit ones are good but too pricey. Ginfull ones are more reasonably priced, just make sure to get the V5 ones.
Here for the calibration: https://dualshock-tools.github.io/
Here for testing: https://hardwaretester.com/gamepad
da
Aggiungi un commento
