Salta al contenuto principale
Il Toshiba Satellite L300 era un notebook progettato e venduto da Toshiba, fornito con una versione di Windows Vista. È stato venduto tra maggio e giugno del 2009 e, sebbene non fosse idoneo per l'aggiornamento gratuito a Windows 7, è passato molto tempo e gli aggiornamenti non sono più richiedibili; il dispositivo esegue correttamente Windows 7 Home Premium senza aggiornamenti, principalmente a causa dell'eccessivo consumo di risorse di Vista. Conosciuto anche come Toshiba Satellite L300-04P (PSLB8C-04P01X).
Won't boot up.
I put the machine into sleep mode then closed the lid. On opening nothing I did would wake it up. Shut it down. Would not then boot up. Tried everything. Took out battery, RAM, swapped SSD, tried booting holding down various key combinations. Lights come on, SSD flickers, but nothing appears on the screen. Thank you for any tips!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
try to clean it first and check that there isn't any falty connections, then consider making a bootable USB for a linux(I'd suggest Ubuntu or mint or Pop for easy use and lots of good youtube tutorials online) and to check that it's not a kind of software bug then try replacing the RAM as it could be faulty RAM Sostituzione RAM Toshiba Satellite L300
hope this helps
Punteggio 0
2 Commenti:
Thank you for your reply. Tried taking out the original and extended RAM cards and swapping over. No joy. It's a Windows 10 set up (been running that since Windows 7 was no longer supported.) Won't boot up off a boot able USB stick and pressing F8 and F12 on start up have no effect. I suppose I could try a new RAM card.
da
I meant to add that I also took out both memory modules and tried each one in the main memory slot, ie, just one at a time. I guess it's possible that they may have both become faulty.
da
Aggiungi la tua risposta
K P Dawson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 6
Tutti i Tempi: 255
