Salta al contenuto principale
Repair information for Asus N Series laptops.
Windows 10 does not recognizes SATA BD-ROM / DVD Rewriter CT21N
I have exchanged the original DVD reader "Super Multi DVD Rewriter Model: GT70N" by a "BD-ROM / DVD Rewriter Model: CT21N".
I was expecting that Windows 10 recognizes the new Bluray reader. Both, new and old one are form Hitachi-LG Data Storage.
I have tried this already:
  • Driver updates from Windows Update → no updates needed
  • ODD Auto Firmware Update from Hitachi-LG (https://hitachi-lg.com/en/support/firmwa...) → The optical disc drive already has last firmware
  • I confirmed in the BIOS if the SATA configuration was ok, I can only change the SATA Mode from AHCI to IDE, so I let it on AHCI
is the laptop too old to use the Bluray drive, althought is SATA?
Any suggestion?
Thanks a lot for your support!!
Updates:
I found the "Super Multi Blu Install Disc" (in the hope to find the Bluray drivers) → https://archive.org/details/super-multi-..., and ran the "BD advisor":
Questa è una buona domanda?
Punteggio 0
6 Commenti
Hi @rolas44998
Windows Device Manager indicates that it is working OK
Can you play standard dvd discs OK using VLC?
If so there may be a problem when only playing BluRay discs.
If you can play dvd but not Blu Ray, it might be more of a problem with VLC
da
Hi! Thanks for commenting, standard DVDs are playing OK. I tried also with PowerDVD 10, but same result :(
da
@rolas44998
What is the model number of the laptop?
PowerDVD 10 upscales the dvd video to HD quality i.e.1280 x 720 resolution, and maybe the GPU (video drivers) or screen in your laptop can't handle it. Same with BluRay
da
@jayeff
It is a N56VJ with a dual graphic card:
- NVIDIA GeForce GT 635M
- Intel HD Graphics 4000
I found the "Super Multi Blu Install Disc" (in the hope to find the Bluray drivers) → https://archive.org/details/super-multi-..., and ran the "BD advisor". Screenshot added in the question.
Do you think it might be a power issue? the Bluray drive is from the same brand as the DVD drive, Hitachi-LG Data Storage...
da
@rolas44998
Have you tried using other video programs instead of VLC e.g Windows Media player and see if it worked?
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @rolas44998
It seems that Win 10 doesn't support Blu Ray therefore Windows Media Player won't work for a start.
VLC can do it but there are a few steps involved to even get it to work properly.
Here's a link that explains it better than I can. There's also this link for the necessary library files (I think).
There's plenty of info online about how to get VLC working for Blu Ray discs.
Punteggio 2
3 Commenti:
Thanks @jayeff! I was thinking that would be as simple as playing DVDs and only by having the player would be enough, but 2 libraries are needed plus a whole catalog of known Bluray disks keycodes.
With your hint I got to this steps: https://forum.doom9.org/showthread.php?t...
Complicated but duable, thanks a lot!!
da
@rolas44998
Yes it did seem like deciding whether to have BluRay is worth the effort of trying to get it to work.
Gives you something to do over Christmas perhaps ;-) Just kidding.
Cheers
da
@jayeff definitelly 😄 happy holidays!! 🎅
da
Aggiungi la tua risposta
Rolas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 91
