Salta al contenuto principale
Informazioni su riparazione e risoluzione problemi per la centrale elettrica portatile FixHub, la fonte energetica principale e l'interfaccia di controllo per la linea di prodotti FixHub di iFixit. In uscita a ottobre 2024.
Has anyone had an issue with the battery erroring out?
Hello everyone,
I purchased the FixHub and it works wonderfully except for one small issue. When powering the iron off, after a while I will receive a battery charging halt error at 98%.
otherwise the iron works fine and discharges and charges as normal. Is this just a visual error, or is there something I should look into? I am on firmware 1.0.5
Thanks!
Questa è una buona domanda?
Punteggio 4
9 Commenti
I’ve forward your issue to the iFixit product team for a response.
da
@danj, thank you.
@kaioshade, we're looking into it.
da
@krisrodriguez Thank you so much for the swift reply.
For some additional information, I am using an Anker Nano II 65W USB-C charger, with an Apple USB-C 240W cable. I have not tried any other chargers yet.
da
@kaioshade, you're welcome!
Thanks for the extra information. I have a follow-up question. Have you calibrated the battery? It's a button in the web UI. It's somewhat expected to have some variance up front with max charging percentages until this is done.
da
@krisrodriguez
I did not do the calibration when I got the unit (apologies, I didn't think to), but I did it tonight. I'll report back if it does happen again. Thanks for the info!
da
Mostra altri 4 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
Mine has only been used a handful of times, and the battery has been self discharging over a week by more than 10%
I also saw that the health percent for it is already down to 89%
Punteggio 1
3 Commenti:
@omegatotal, have you tried updating to the latest firmware?
da
I just did through every version, now the battery health is MIA, and replaced with a setting for setting the max battery charge.
Also it appears that it is not respecting the inactivity/timeout that I had previously set to 30 minutes (its stayed on for multiple hours today after a couple of power cycles)
da
I just tried changing it to 29 minutes and back to 30 minutes after it stayed on without being touched for 2 hours. lets see what it does this time.
da
Aggiungi la tua risposta
Cien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 403
