Salta al contenuto principale
Informazioni su riparazione e risoluzione problemi per la centrale elettrica portatile FixHub, la fonte energetica principale e l'interfaccia di controllo per la linea di prodotti FixHub di iFixit. In uscita a ottobre 2024.
Factory reset, CLI serial commands
Hi, does anyone know a command to return the FixHub to it's original shipped state?
Am thinking this would be via a terminal session, as the "knob" doesn't seem to show this option.
Also, is there any documentation on the CLI serial commands?
Some, like mcu-sn or toolinfo, are fairly straightforward, but am wondering if there's a comprehensive list of the other commands, similar to a man page.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @osxtra ,
There is no menu setting on the Power Station to reset factory defaults, nor is there on the web interface (currently).
In the meantime, these are the default settings:
Language (English)
Power-Off Timer (10 min)
Timer Enable (Enable)
Max Charge (100%)
Error Log (clear error log)
We also don't currently have a public spec for the serial terminal commands. We might in the future.
Punteggio 1
4 Commenti:
Tanks for the info, Kris!
da
I do not see the option "Max Charge" in my menu. Is this part of an update?
da
@omegatotal Yes, you should be able to see this option once the firmware is updated (not sure what exact firmware version number this would be when this option first appeared).
da
Nice 6 month turnaround
da
Aggiungi la tua risposta
osxtra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 269
