Chip out of cooktop
How can I repair a small chip broken of the smog induction cooktop?
It happened when a knife was dropped hitting the side.
Only small but noticeable
Thanks
Questa è una buona domanda?
Thanks
If you have the chip and it fits cleanly in the space you could try a good cyanoacrylate glue like Loctite 1364076 Super Glue Easy Squeeze Gel. But it can’t be near the heated area as over time it will degrade.
If the chip is on the surface and/or you don’t have the loose piece you could use a black epoxy filler. First taping down the area to protect the rest of the area and limit creep of the area being filled. Keep in mind you may end up with a bump or still have a divot where the hole is. Using a knife to trim it may put the fill out and you don’t want to sand as the glass surface will then get scratched.
The bottom line it might be just better to accept the damage than trying to fix it.
Thanks Dan, l do not have the chip, l better leave it and avoid looking at it.
Thanks for your advice
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 73
Tutti i Tempi: 466
5 Commenti
Is the damage along the edge or near the coil areas? Can you post a few pics so we can see the damage clearly.
da DanJ
The chip is along the edge, l will try and send some photos
da John Wagenaar
Sorry don’t know how to send photos 😔
da John Wagenaar
@johnwagenaar We get that question a lot, so here's a page showing you how to add images to your question.
Aggiungere immagini ad una domanda
da Jerry Wheeler
Thanks for the information, Jerry
da John Wagenaar
