Salta al contenuto principale
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
798 Domande Visualizza tutte
Blinks green than red while charging
When charging my Kindle Fire its turns green than red and it doesn't turn on and now its blinks a steady green light and it doesn't charge with the Kindle Fire original charger... What doI do at this point.... it hasn't charged properly sense I brought it.... Need Help Very FRUSTRATED....
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
5 Risposte
Risposta Più Utile
Is your Kindle Fire still under warranty? I'd suggest having them replace it if it's not working.
Punteggio 1
Do you know for sure that the original charger is working? Can you borrow one from a friend and try it?
You can also charge the Kindle Fire from a micro-USB connector that is plugged into a USB port on your regular computer. (The Kindle doesn't charge as fast from your PC, though - the USB port on a PC will only supply 500 mA for that purpose.)
I don't recall such a cord (USB to micro-USB) coming in the box with my Kindle Fire. I picked a cord up somewhere locally - probably at Fry's - and use it to both charge the little beastie and transfer files (music, books, videos, documents) onto it.
Best of luck - I wasn't overwhelmed with my KF to start with, but now that I've loaded some useful things onto it (flashlight, wi-fi analyzer, graphing calculator, etc.), I find myself carrying it around to my various workplaces to use as much more than just an e-reader.
Punteggio 0
Okay. My kindle fire charger part inside broke. And I don't have warwnty. And I know how to repair things. I just need to know where to get a replacement. Any help?
Punteggio 0
Contact Amazon and ask them about purchasing a new charger.
Or Google "Kindle Fire Charger".
Amazon is the main source for Kindle Fire products since they're so new.
There are a very few generic replacement power supplies available if you check the Google search pages closely.
If you mean the USB connector inside the Fire, the only likely place to obtain internal parts would be Amazon. Contact their Customer Support for information about obtaining parts.
Punteggio 0
Learn English
Kindle Fire it turns green then red
hasn't charged properly since I bought it
Punteggio 0
Aggiungi la tua risposta
Ginger sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 31
Tutti i Tempi: 17,198
