Salta al contenuto principale
Informazioni sulla riparazione e sullo smontaggio dello smartphone Google Pixel 8a, lanciato il 14 maggio 2024. Identificabile con i numeri di modello GKV4X (5G Sub 6GHz) e G8HHN (5G banda millimetrica + Sub 6GHz).
FingerPrint doesn't work after screen replacement
Hi, I recently made a screen replacement over my Pixel 8a (EU-630084) with no problems.
After replacement, I did the fingerprint calibrate process with my laptop. Any error received, but after reboot my phone, the diagnostic process says the fingerprint FAILS. What can i do
Questa è una buona domanda?
Punteggio 7
1 Commento
You need to ask for a new replacement. The new one works fine.
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
I completed replacement yesterday, same issue.
Is there a missing instruction ?
Punteggio 0
1 Commento:
Yes ensure that while you are changing the display kindly see the connector of fingerprint scanner is properly connected to displays connector or glass was clean and neet
da
It happend to me as well.
Something must not be right
Punteggio 0
I'm not sure how this is answered? I'm facing the same issue
Punteggio 0
1 Commento:
You need to ask for a new replacement. The new one maybe works fine
da
Aggiungi la tua risposta
Carles Gomez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 38
Tutti i Tempi: 897
