Salta al contenuto principale
Wireless communication devices, primarily used for referees.
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
Questa è una buona domanda?
Punteggio 1
2 Commenti
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. Aggiungere immagini ad una domanda
da
@oldturkey03 done, thank you for that tutorial :)
da
Aggiungi un commento
1 Risposta
Risposta più utile
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
Punteggio 1
Aggiungi la tua risposta
Mike Texter sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 127
