Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD devono essere sostituiti come un'unica unità. GSM / 8, 16 o 32 GB di capacità / Modello A1332 / Nero e Bianco. Questa pagina ha lo scopo di aiutare gli utenti a risolvere i problemi, riparare e cercare aiuto per l'iPhone 4.
How to Install Itunes For iPhone 4 .
How to install iTunes on iPhone 4 device. And how do I install it? And can i install myself.
Questa è una buona domanda?
Punteggio 2
7 Commenti:
To be clear, the iTunes app itself isn't appearing on your device?
da
This question is really vague. Like it could mean what version to install on Mac or P.C to connect the phone for certain exploits or anything 🤷‍♂️
da
@muhammadsa29369 We prefer you not hold private conversations with our contributors, as the purpose of this site is to help others. As such, any assistance you get in private helps you and only you, whereas posting a question on this site allows everyone to benefit from whatever you learn.
da
@muhammadsa29369 use this guide Aggiungere immagini ad una domanda to add pictures to your Question.
da
Mostra 2 altri commenti
Aggiungi un commento
2 Risposte
iTunes is installed by default when you got your phone. Did you remove it somehow?
Depending on the version of iOS you should be able to see it looking at the icons it’s a Purple box with a White five point star in it. You can also go into search and type iTunes to locate it if it’s not visible.
If you removed it you’ll need either use this to access it via the iPhones Safari web browser How to Download built in Apple Apps for iOS from the App Store. Or connect your phone to a Mac system with iTunes to re-install it.
Punteggio 0
@muhammadsa29369 not sure why you would want to install iTunes on your phone. You do not need it to play music. For that you use the innate App "Music". Where you do need iTunes, is on your computer. You use that to sync your iPhone with your computer, not the other way around. Remember, your iPhone cannot be upgraded with anything above iOS version 7.1.2
Do not get confused with the iTunes Store App, which uses a purple box with 5-pointed white start in it, as icon. That is not the iTunes you need to sync your music/files :-)
Punteggio 0
Aggiungi la tua risposta
Muhammadsalim Mamadaliyev sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 29
Tutti i Tempi: 742
