Salta al contenuto principale
Released in April 2022, this 5G-capabable Moto G has a 6.8 inch 120Hz LCD display at 1080 x 2460 pixels, Qualcomm Snapdragon 695 Chipset, and wide 50 MP, ultrawide, and depth cameras. Model XT2215.
14 Domande Visualizza tutte
Switch the motherboard from my phone to a new one
Will it be hard to switch the motherboard from my phone to a brand new phone so I can get a my information ?my digitizer and screen is gone in my old phone by the time I ordered one had it installed and all of that plus me having no transportation around .It was going to be a lot cheaper and quicker to do it this way .I am determined to show all the people that said I couldn't do it that I can so I am all the phone's memory is on the motherboard isn't it and another thing when i took the back off of my old phone there was double sided tape on the back can i use that t secure it.
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi, I’m sure the community would like to help but there’s not enough information of what’s wrong with the original phone.
If you can explain why you can’t access the data on the phone and what replacement phone you are going to try and use might help to produce answers.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Abigail,
I'm having to make a few assumptions here, but if those assumptions are true, then yes, it is definitely possible to do what you want.
I'm reading your question that you have a broken phone with an intact and functional motherboard and would like to purchase a brand new phone of the exact same model, then swap out your motherboard for the one in the new phone, thus fixing everything that was wrong with your old phone and allowing you to access all the data that was on the original phone.
If that's the case, then indeed, it should work perfectly. All you need is to follow the motherboard replacement guide twice; once to remove the motherboard from the original phone, then again to take out the motherboard of the new phone. Reassemble the new phone with the old motherboard and you should be all set. Read through this guide, and if you think you can follow the instructions then go for it!
Motorola Moto G Stylus 5G (2022) Motherboard Replacement - iFixit Repair Guide
If you need any tools, you can buy them right here on iFixit; the guide tells you everything you need. The only other thing you might have to have is a sheet of precut adhesive to glue the rear cover back on the phone once you're done, which you can also buy here on iFixit.
ifixit.com/products/motorola-moto-g-stylus-5g-2022-battery-cover-adhesive
If you have any questions, feel free to ask, otherwise good luck with your repair! Once you're done, come on back and let us know how it went; success stories are always appreciated, and we can usually learn something when things don't go as planned.
Immagine This custom cut adhesive film secures the back panel to the case in a 2022 Motorola Moto G Stylus 5G smartphone.
Prodotto
Motorola Moto G Stylus 5G (2022) Battery Cover Adhesive - Genuine
$3.99
Punteggio 1
Aggiungi la tua risposta
Abigail sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 82
