Salta al contenuto principale
HP ZBook 17 G2 Category: Mobile Workstation System SKU: G6Z40AV
كيفية تشغيل كارت الواي فاي
WiFi doesn't work
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@hpzbook17g2 you are not telling us what OS you are using. Check in the device manager and see if the WiFi adapter is listed. If so, uninstall the driver for that. Now reinstall the driver for that. If it does not show up in your OS then check your BIOS to see if the WiFi card does show up. Again, if it does not then it is possible that your adapter has failed. Use the HP ZBook 17 G2 Maintenance And Service Guide to check the BIOS, as well as check the hardware. It will also show you how to replace the WiFi adapter if needed.
Punteggio 1
Aggiungi la tua risposta
Hp zbook 17 G2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 15
