Salta al contenuto principale
Power button light not working
The light on my on/off button doesn't light up on my xbox one x gold rush edition the console starts up fine and works perfectly any ideas why the light won't work
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Tom!
Most of the time it's either the PSU or the motherboard.
I would try a new PSU first! You can buy a replacement PSU and try it. If this didn't solved it, then return it and get yourself a refund.
Could also be the front circuit board. Does the Xbox power on with the controller?
I would try a new PSU first.
Punteggio 2
8 Commenti:
Yes the console powers on with the controller
da
Alright, this changes it. Then it's probably the switch which is faulty. The PSU and motherboard should be fine. Please try a new front circuit board first. This will most likely solve it. This is the one you need: https://www.amazon.com/Internal-Circuit-...
da
The console is a xbox one x by the way
da
Yes, the part in the link I've sent is for the Xbox One X :)!
da
Thank you for the help hopefully I can fix it
da
Mostra altri 3 commenti
Aggiungi la tua risposta
Tom Bowden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 55
