Salta al contenuto principale
Top di gamma Huawei rilasciato a novembre 2019. Ha una fotocamera quadrupla, una batteria da 4500 mAh e il sensore delle impronte digitali integrato nello schermo.
3 Domande Visualizza tutte
I want use google play
how to use google in this handphone
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
Huawei are no longer able to sell phones with google apps installed but I did find this information on how to install what you need by downloading the APK’s.
  1. o to the Huawei/Honor app drawer.
  2. Locate the Settings app and tap on it.
  3. Next, you need to select “Advanced Settings“.
  4. Tap “Security” and then tap “Enable Installation from Unknown Sources“. You can also check our guide on how to enable Unknown Sources on Huawei.
  5. You will see a notification “This type of file can harm your device“. Simply ignore it, as it is completely safe. Tap “OK” to continue.
  6. Download the following 3 files to your device storage.
  7. Once downloaded, you need to install all three APK files one by one on your phone.
  8. Go to the app drawer and launch Google Play Store on successful installation.
  9. Log in with your Google account to start using the services. If you don’t have a Google account, create one.
That’s it! You have successfully installed Google Play Store on your Huawei Chinese mobile. You can now start downloading your favorite apps from the Play Store.
With any luck this still applies and has not been blocked.
Please be aware that this will require you to install from unknown sources, so you have to decide if that is an acceptable risk for your situation.
Hope this helps
Punteggio 0
Aggiungi la tua risposta
Jahe Sereh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 53
Ultimi 30 Giorni: 80
Tutti i Tempi: 137
