Salta al contenuto principale
Flap stays open while AC is off
Both of my Daikin air conditioners have recently developed a problem where the air flaps remain open even when the units are completely turned off. Does anyone know how to fix this issue?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @tlblkrn
What are the model numbers of the air con units?
da
@jayeff Hello, Both of them are of Daikin MODEL: FTL18TV16T2D
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @tlblkrn
Unfortunately I cannot even find a user manual for the model number you posted let alone a service manual or parts list for it.
The best that I can advise is try a power reset and check if they perform correctly.
Turn off the units if they are on and disconnect the power to the units i.e. remove the designated fuses or trip the designated breakers for the air con units in the house power box, for 5 minutes and then restore the power to the units and check.
The image below is what Daiken suggests but presumably you've already tried this.
(click on image)
Punteggio 1
Aggiungi la tua risposta
Akib sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 123
