What should I do with E4?
After working for a few minutes, it starts beeping and shows error 4 on the screen, I don't know how to fix it.
Update (07/18/24)
Questa è una buona domanda?
Yes, you have a GE GBT412SIMII model dishwasher.
Is there standing water under the tub at bottom of the dishwasher?
If there is then it may be due to a leak in the dishwasher which has activated the flood switch
If there's no water it could be a faulty flood switch.
Tilt the dishwasher forward and check if any water drains out.
Unfortunately I cannot find the service manual (look behind the kickplate -toe plate to see if it is there in a plastic sleeve) or any parts for your model.
There is no standing water under the tub at the bottom of the dishwasher. The dishwasher continuously drains, and if I add water, it drains immediately, making a sound as it does so. Since the dishwasher is built-in, I need to remove it to check further, but I don't have a screwdriver to take it out.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 252
3 Commenti
Hi @babakvakilian
What is the model number of the dishwasher?
da jayeff
Hi @jayeff and thank you , is it correct ?
da Babak Vakilian
da Babak Vakilian
