Salta al contenuto principale
The Lenovo ThinkPad X1 Carbon 8th Gen comprehensive repair guide is designed for students, professionals, and technicians. It provides detailed steps for troubleshooting and efficient problem-solving.
4 Domande Visualizza tutte
How I can change ram
i want to replace ram
and want to upgrade 8 gb to 16 gb
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @adnanhassan
The memory is hard mounted on the systemboard and cannot be replaced.
To upgrade the amount of memory you would have to replace the systemboard.
Here's the hardware maintenance manual for the laptop. Go to p.86 to view the procedure to remove/replace the systemboard.
Here's the parts lists for the MT 20U9 and 20UA models, that may help. (check for the MT number on the product information label on the bottom of the laptop).
Click on Select Commodity - System Boards (110) to find the part numbers for the 110 different systemboards that are used in the laptop. If you click on the Specs link in each part you'll see the relevant specifications of the motherboard.
Punteggio 1
Aggiungi la tua risposta
Adnan Hassan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 75
Tutti i Tempi: 326
