Salta al contenuto principale
This multimedia-geared dv6 comes with a 15.6-inch display, a built-in stereo, and weighs just under 7lbs. It is simple to disassemble- only a small screwdriver and a paper clip are required.
Why my laptop didn't start up while the charger connected
My laptop didn't start up while the charger connected and the charger led turn on and off
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@shadyfathy could be an issue with the charger of the DC-in jack. Try the easy stuff first. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Aggiungere immagini ad una domanda
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Punteggio 0
Aggiungi la tua risposta
Shady Fathy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 34
