Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
Why does my RH controller keep losing connection?
Using my red RH controller it loses connection and re connects over and over. It doesn’t seem to be a battery issue but I haven’t ruled it out.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Chrisa!
The right one does have an antenna connected to it's motherboard. Please open the Joy-Con and check if the antenna is still connected properly to the motherboard. This could cause the random disconnects.
Does the Joy-Con work perfectly fine while attached to the Switch?
Could also be the "Broadcom BCM20734 Bluetooth 4.1/2.4 GHz Transceiver IC"...
This required soldering plus soldering skills to get it fixed.
To test if it's the battery or not, you can also buy a grip holder with USB-C! While it's connected to the cable and still losing it's connection, it's definitely the blue-tooth messing around.
Good luck! And please let us know how it goes!
Punteggio 1
Aggiungi la tua risposta
chrisa4357 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 204
