Salta al contenuto principale
Repair and further information for the GE Refrigerator GNE27JSM****, a French Door style refrigerator with a bottom-mounted freezer, automatic defrost and ice maker features. This page covers information for model numbers matching the pattern GNE27JSM****.
Identity defrost timer. Frog warm, freezer icing up
Is defrost timer part of control board ?
Defrost sensor good and heater good. Both continuity.
Where is heater fuse located.
My model is GNE27jymnffs, same as above model except JYM. S JSM model
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @davidverbeke
The defrost timer circuit is part of the control board.
Here's the mini manual for the model.
Run the diagnostic test mode t11 to test the defrost feature as described by the manual
Looking at the schematic the defrost heater gets power from control board plug connector J19 pin 2.
Looking at images of the control board (p/n WR55X40448) there's a relay right next to the J19 plug socket, so perhaps it has to operate so that power is extended to the heater when required. It may be worth checking.
Take note of what it states for the t11 test regarding why the heater may not turn on. Did you check the freezer evap temp sensor is OK?
Punteggio 1
Aggiungi la tua risposta
David Verbeke sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 100
