Salta al contenuto principale
The truck has a new exterior profile taking styling cues from the 2014 model year 4Runner SUV and the 2014 model year Tundra pickup and features a much more aggressive and masculine look, with a larger grill and new projector beam headlamps.
Pressing gas and brake simultaneously warning light
Once in awhile a warning light comes on with a foot and pedal on it, when I accelerate. When the light is on the truck seems to be in limp mode, and will not go over 5 miles or so. What is causing this? how do I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @luthermanriquez
The warning light indicates brake override malfunction.
You're not the only one to have experienced this problem. Here's a link that describes what others have tried and found (or failed to find) caused the problem.
Since your problem is intermittent it may be more difficult to isolate but perhaps first check if the 10A Stop fuse #28 in the engine bay fuse box is OK. Also check that the taillights are all working OK and not that one is dimmer than the rest, as these two things seem to have some affect whether it occurs or not.
Punteggio 1
Aggiungi la tua risposta
Luther Manriquez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 67
