Salta al contenuto principale
The Casio Tough Solar Illuminator is a solar-powered "G-Shock" style watch featuring backlight, 5 alarms, stopwatch, timer, and world time.
Delay in analog time
My watch showing 15 minutes delay in time later than the actual time which is digitally correct , How to fix it ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @ahmedkhatt91838
What is the model number of your watch?
Here's an image that shows how to adjust the analogue time in a Casio Solar watch, so hopefully the procedure is the same for your model.
(click on image)
Punteggio 1
3 Commenti:
Model Number : 5208AQ-S810W
da
@ahmedkhatt91838
Did you try the procedure shown in the images above, you didn't say whether you did and it worked or you did and it did not work?
da
Thank you , it didn't work but I asked chatGPT and surprisingly it sort it out
da
Aggiungi la tua risposta
Ahmed Khattab (Clavicle87) sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 206
