Salta al contenuto principale
Display LCD widescreen da 4.3’’ con processore da 333 MHz. Numero di modello PSP98510. Riparare questo dispositivo richiede cacciaviti e strumenti per fare leva.
Why is my psp loading forever?
I recently opened up my psp 2000 and after replacing the joystick as it was broken it stopped loading UMD Discs. It has the loading icon but after about a minute it just says "disc could not be read" on a game that worked on it previously and my other psp. Did i disconnect something? Do i need to lube the gears as it's making a whirring noise now? Any help is appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Well first thing to do is to open it up again and be sure that all is connected properly!
Also check if something is damaged (cables etc).
If you are uncertain about a component, please share some pictures with us!
Punteggio 1
Aggiungi la tua risposta
ballisticzombie7 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 142
