Hi @naahkpan
A two blink Caps lock light error code indicates a problem with the BIOS.
Try a full power refresh (aka BIOS reset) and check if that resolves the problem.
Here's the procedure:
Disconnect the charger if connected and turn off laptop if it is on.
Remove the main battery from the laptop
Open the laptop and then remove the RTC coin cell battery from the motherboard. Unfortunately for you, the RTC battery is located on the underside of the motherboard, so you will need to remove the motherboard from the case to get to it.
Here's the maintenance and service guide for the laptop. Go to p.55 and p.103 to view how to remove the battery and RTC battery respectively.
When you have removed the RTC battery, measure its voltage. if it is <2.6V DC or >4-5 years old, replace it. Search online for 683502-001 to find suppliers that suit you best.
Reverse the above steps to reassemble the laptop and check what happens what you try to start it.
If it starts OK there may be a message regarding the date and time being incorrect. This is normal as the BIOS has been reset. Once the D&T have been adjusted, the message won't appear the next time the laptop is started.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
