Legion slim 5 screen broken
Hello friends, I hope you're doing well.
I have a Legion Slim 5 laptop, and its display has an issue where the lower half of the screen gets corrupted every 4 seconds and then returns to normal. I've switched between the two graphics cards, but the problem persists. I also tested it in the BIOS and Windows Safe Mode, and the issue still remains. The graphics card drivers are up to date.
This started happening during a game. Currently, there is no drop in processing or graphics performance, it's just this display issue that occurs every 4 seconds.
It's very likely that the issue is either with the display connections or the display itself. I've attached a picture of the laptop
. I would appreciate it if you could share any similar experiences or knowledge you have regarding this issue.
Model: Legion Slim 5 2023
CPU: i7-13700H
GPU: RTX 4060
Display: 2560*1600 165Hz
Questa è una buona domanda?
Hi @arminshekofte
Does it also occur when viewing it on an external monitor (TV?) connected to the laptop?
da jayeff
@arminshekofte have you tried to change the refresh rate and checked to see if that makes a difference?
da oldturkey03
