Salta al contenuto principale
Samsung Tablet from 2021. The model number is SM-X200 or SM-X205
7 Domande Visualizza tutte
I spilled water on my tablet.
I spilled water on my tablet, and it wouldn't turn off for 3 minutes, so I had to power it off. I left it in my room, and my AC is broken so the house is 90 degree fahrenheit. What do I do next?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @albert77027
What is the model number of the tablet?
In the meantime do not attempt to turn on the tablet or to charge it as this will only cause more damage than what there already is.
Knowing the model number will help to give you a better answer as to what exactly needs to be done to hopefully fix it and get it working again i.e. how to open the tablet, how to clean it correctly etc.
Punteggio 1
6 Commenti:
I do not know the model number, but it's samsung galaxy tab a8. My tablet is still off and not charge
da
@albert77027
You will find the model number on the back cover of the tablet, near the bottom.
It should begin with SM-T??? or SM-X???
There are a lot of Galaxy A8 models so knowing the exact one will help to find the correct parts if any replacement parts are needed.
da
it have been 20 days, and my tablet is working fine now.
da
@albert77027
I would still check if the LDI is indicating that water entered the tablet or not.
You may have been lucky but if the LDI shows that water has entered the tablet then it will eventually fail. Maybe not soon but ......
da
@jayeff The LDI is fine and show no indication.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Albert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 77
