Salta al contenuto principale
Smaller, thinner, quieter model of the Playstation 2 (SCPH-700xx) released by Sony in September, 2004.
Laser lens is always going forward and gets stuck on disc turntable
Hello I bought ps2 770xx everything was good until one day laser lens started going forward and gets stuck on disc turntable and it starts make clicky sounds. Please help <3. Thank you
Questa è una buona domanda?
Punteggio 0
1 Commento
Hey I opened it and it was only because the ribon cable was disconedted. Thanks for help
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi!
Okay, click sounds most of the time points to a faulty worm motor and thus it need to be replaced.
Please open up the PS2 Slim and first check the laser slider, if this looks all good then test the worm motor. You can test it with putting (carefully) some presure on the slider and see if the worm motor let the laser move freely. If the laser is stuck or does not want to move easly, then the worm motor really need a replacement.
Please let us know how it goes and good luck!
Punteggio 1
4 Commenti:
Hey i think that motor is ok. The clicky sound is made by the laser lens is bouncing of the disk turnable in middle.
da
Hmm, do you have a video for us to show us what exactly the laser is doing? Thanks in advance!!
da
da
Hi!
Ah! Glad that it’s just the ribbon cable!! My pleasure! Good luck with gaming :)
da
Aggiungi la tua risposta
Frost Man sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 31
Tutti i Tempi: 266
