Salta al contenuto principale
Repair guides and support information for Lenovo's IdeaCentre series of all-in-one desktops.
screen replacement for ideacentre aio 520-22icb
I have a lenovo ideacentre aio 520-22icb i ended up cracking the screen while trying to upgrade my ram but the problem i ram into is finding the touch screen for it so i could replace it do you guys have any ideas where i can find one for it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @chrispoole12117
The display panel comes as a complete module assembly consisting of the LCD panel and the touchscreen panel i.e. not two separately removable/replaceable components.
Here's the hardware maintenance manual for the AIO.
Go to p.56 to view the procedure to remove/replace the LCD panel module.
Search online for 01AG987 (or 01AG923 - equivalent substitute panel) to find suppliers that suit you best. - (suppliers examples only)
Punteggio 1
2 Commenti:
the removal part is not the issue its finding the replacement screen thats the problem i dont know where i can find one.
da
@chrispoole12117
There is no separate digitizer panel or at least the manufacturer doesn't list one. They only list 4 LCD panels for your AIO model i.e. 2 with touchscreens and 2 without
As shown above, search for the part numbers to find suppliers for the LCD+digitizer panel.
If there is a separately removable digitizer panel then check for the part number on the panel itself (if there is one) and then search for that.
da
Aggiungi la tua risposta
Chris poole sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 315
