Why is the hotspot does not have the range
if u r using hotspot other phones wont get any range atleast close to the phone
Questa è una buona domanda?
Hi @jerohnjoshy
Check if the antennas in the phone are securely connected.
Here's an image taken from this teardown video showing where to check.
(click on image)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 130
6 Commenti
It could be your antenna, how is your bluetooth connectivity range?
Is it the same of longer?
da Hampter
yes even the bluetooth is also same like hotspot
da Jerohn Joshy
@jerohnjoshy
What's the phone's normal WiFi connection distance like e.g. when connecting to a WiFi router?
It should be further than BT as BT is only ~30' (10Metres) due to less power being used for BT even though they use the same antenna.
da jayeff
@jerohnjoshy is it giving a hotspot to someone else or someone giving you a hotspot
da Hampter
@hampter hotspot to someoneelse
da Jerohn Joshy
Mostra 1 altro commento
