Washer makes noise and won’t drain all the way
Hi, I have a kenmore he washer 110.26002011 type 588-06. It won’t start a cycle. It will attempt to start and make some noises, including a rumbling noise. It will then quit. I thought it was the drain because I can hear water still in the bottom when I spin the tub by hand. I made sure the drain hose was clear. I took off the drain pump and removed a small piece of yarn and plastic. I then opened the top and found about 6 socks between the inner and outer tub. Removed socks, 2 bobby pins and replaced drain pump. It still isn’t fixed and makes a couple of strange noises that I recorded. What’s the next step? I need help.
Questa è una buona domanda?
