Salta al contenuto principale
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
17 Domande Visualizza tutte
Why is my laptop GPU not being recognised by my laptop?
I opened my laptop to clean the dust and the fan etc. however I didn't take out the battery inside the motherboard and whilst i was cleaning it and I accidently dropped my screwdriver on near the GPU area and it caused an electric discharge and now that i turned the laptop on it doesn't even recognise my GPU and its using only integrated graphics card that came with the CPU. What i can do please help.
Theres no physical dents or damages, only thing that happened was the electric discharge and the GPU no longer works or turns on (GTX 1650)
I tried to fix it but i don't think i can since its probably a power issue where the power isnt going there if not maybe a discharge towards the GPU im not too sure, please answer anyone
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@vyenea sounds like you have shortened out a component on your motherboard. You will have to really look around the area where the screwdriver may have done the damage. If nothing else post some very well focused images of your board with your Question. Something that will allow us to zoom in and help you with trying to find those components.
Your motherboard should be a FH50Q LA-J621P but you will have to verify this for us.
Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
vyenea sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 45
