Salta al contenuto principale
Lanciato il 20 settembre, l'iPhone standard di Apple del 2019 ha LCD touchscreen da 6,1" e doppie fotocamere ed è disponibile in sei colori. È il successore dell'iPhone XR.
Broken cable flex [help]
Hey everyone! I accidentally broke a cable inside my phone (I’ve attached a picture to show you which one is broken) I’m wondering if this is replaceable and if so which part do i need? Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
This is the cable that goes to the receiver speaker and front facing sensor assembly. It is attached to the back of the screen. It is in fact replaceable, but without some extra Apple magic (or a programmer) you'll lose Face ID function since there are components on the cable that are paired to your specific logic board (the flood illuminator specifically).
How exactly did you break the cable? Is it torn? Depending on what happened it may be fixable, but your best bet is likely to replace the component.
Immagine Replace the earpiece speaker and sensor assembly compatible with the iPhone 11 model #A2111, A2221, A2223. Fix problems with phone call audio and sensor functions.
Prodotto
iPhone 11 Earpiece Speaker and Sensor Assembly
$19.99
Punteggio 2
Aggiungi la tua risposta
Lauren H sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 256
