Salta al contenuto principale
Originariamente identificata internamente come LFA, la Sonata del 2015 è stata presentata in Corea a fine marzo 2014 ed è stata svelata in America al New York International Auto Show del 2014.
Changing front bumper out
Replacing front bumper, thanks
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @simon52118,
What is the year model of the vehicle?
da
Also, are you referring to the metal bumper itself, or just the bumper cover that goes over it?
da
Aggiungi un commento
1 Risposta
Risposta più utile
@simon52118 these don't have much of a bumper behind the cover. You'd be more looking at the radiator grill. Anyhow, this from the service manual 2014 to present:
Immagine
1. Front bumper cover
2. Front bumper side bracket
Replacement
  • Put on gloves to protect your hands.
  • When prying with a flat-tip screwdriver or use a prying trim tool, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
  • Use a plastic panel removal tool to remove interior trim pieces to protect from marring the surface.
  • Take care not to bend or scratch the trim and panels.
1.Loosen the front bumper upper mounting clips.
Immagine
2. Loosen the front bumper lower mounting clips.
Immagine
3. After loosening the front bumper (A) side's mounting clips and screw, then disconnect the side's.
  •   Remove the front bumper by pulling up the side of the front bumper and then pull it out.
  • When you pull out the front bumper, the side part of the front bumper could be damaged by the projection.
Immagine
4. Disconnect the front bumper main connector (A).
Immagine
5.Remove the front bumper cover (A).
Immagine
6. Install in the reverse order of removal.
  • Make sure the connector is connected properly.
  • Replace any damage clips.
If this is not the right model, then you need to let us know the exact year for your Sonata!
Punteggio 1
Aggiungi la tua risposta
Simon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 637
