Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
screen broke into two pieces
Hello,
I wanted to repair my screen but i encountered with a serious problem. My screen broke into two pieces therefor i can't remove it with the suction cup i guess, what should i do? I think i can remove it with my hands actually, will it have the same affect? (the LCD is also broken.
Can I remove the screen simply with my hands and than remove the LCD with the suction cut?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
what i did is i pushed the screen upwards to make a small gap at the bottom and slide a one-side razor then pry it open, just try to avoid damage to the screen gasket.
Punteggio 0
Aggiungi la tua risposta
Mark Vaykhansky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 348
